red31 wrote:
wa8yxm wrote:
Thankfully the Excess flow valve did what it is designed to do and prevented just that.
The spring load shut off valve that works in conjunction with a thermal bushing in the ACME worked, designed to SHUT OFF if the thermal bushing melts from fire and prevent propane flow unless something is attached. Nothing to do with Excess flow feature.
A little confusion going on
OPD Valve Portable Cylinders are all inclusive
*Service/Vapor Valve-----manual shut off valve
*Overflow Protection Device.....internal float that shuts off liquid propane flow at 80% when FILLING
*Liquid Level Bleed Valve....needle valve used to indicate liquid level (80%)
*Spring Loaded Shut off Valve.....prevents ANY vapor flow OUT if nothing is attached to OPD (shut off valve has to be forced open against spring pressure)
*Safety Relief Valve.....Opens on high internal pressures roughly 312#
ACME Nut
*Center 'stub' that forces OPD Spring Loaded Valve open when Nut is tightened.
*Excess Flow Device----Ball Bearing that will CLOSE when pressures on each side of Ball Bearing are NOT equalized. Light spring 'centers' ball bearing inside the ACME Nut. If downstream pressure drops then Higher upstream pressure will force Ball Bearing Closed limiting flow of propane
*Thermal Bushing.....if exposed to high temps/fire it will melt allowing the OPD Spring Loaded Valve to push 'stub' into ACME Nut and CLOSE stopping ALL propane vapor flow out of cylinder
ACME Nut Center 'Stub'
ACME Nut Excess Flow Device
ACME Nut Thermal Bushing ----OLD Style Type I
NEW Style Type I Thermal Bushing
