Just purchases a Mr Heater Big Buddy, and found you're not supposed to use larger than #20 bottles according to instruction pamphlet. Is there no way to hook into an existing line ?
I just got a Big Buddy with the adapter hose and it worked with a 5 lb. tank. I don't know why it wouldn't work if you had a T connection on your larger propane tank and connected the adapter hose. But, you will be limited by the length of the adapter hose...not sure if you can get one in longer lengths.
