amdriven2liv's avatar
amdriven2liv
Propane issues
Ok, here is the deal. We are hooked to a 100lb propane tank. When the tank gets down to around 30%, the indicator on my regulator shows red. Supply is switched to the 100lb tank feed.
I try to light the stove and the propane flow (flame) is real low. Furnace at this point doesn't work. I turn the furnace to off. I let the stove flame for a bit and the flow gets better. Then I'm able to turn the furnace back on.
Any thoughts?
