BB_TX
May 02, 2016Nomad
Do you have one of the small red regulator valves in the propane line, typically in the propane compartment on the opposite side from the switch over regulator valve? Those often start to leak. And they will leak thru a small vent hole on the bottom (that I did not know was there at the time). Mine started leaking and even though I sprayed soapy water and leak detector all over it, there were no bubbles. And there were no bubbles from any of the connections. Finally took the red regulator off and there was an oily residue around the vent hole. Replaced the valve and no more propane odor.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
