Old-Biscuit
May 01, 2015Explorer III
buylow12 wrote:
It's a 2004, I just flip a switch and it lights. I could post a picture when I get back over there this evening if it's not clear. It's got a little flame that lights just below the regulator and then the burner under the water tank. Is that not the norm anymore? The problem seems to be that it's lit when I have it off.
You have a leak...........but it is NOT the LP Regulator (that is device at the propane cylinder)
With WH being electric/propane combo that is not a 'pilot' flame.
The water heater GAS VALVE is leaking thru. That is why you SMELL propane at WH and that is why you can get a flame to light off w/o WH is service.
The GAS VALVE has to be replaced to fix this issue. (they are not serviceable)
What Brand/Model...........Suburban/Atwood.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
