This goes back several months, Jan 2016. We store our fiver in our sons pole barn year round except when it is in use. But my grandson called us early on day stating that there was a very strong smell...
A drop in the pressure indicates a leak in the system. The leak should be located using an approved leak detector or by using leak detection fluid. Once the leak is located, the section should be repaired and the system tested again.
I don't see there this indicates that a travel trailer is designed to have allowable small propane leaks.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
