MrWizard
Sep 09, 2020Moderator
Did you look in the kitchen
Near the floor
For the "Tell Tale"
That's the propane leak detector that controls the LP valve, it must be turned on
It will blink an led and chirp for a minute or so
Once done chirping the propane will be on
Mine will shut off the propane, if I have the entry door open while idling the engine,
At that point it beeps really loud and annoying until I reset it by turning it off then back on
It is there as a safety feature
Losing 12v power, disconnecting battery cables etc..
Will turn it off, and you have to switch Off then back On
Near the floor
For the "Tell Tale"
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
Related Content
- Feb 01, 2026Community Alumni
