dougrainer
Sep 09, 2020Nomad
Monaco Motorhomes have a electric ON/OFF solenoid due to the tank being in the center of the frame and not accessable. IT IS NOT connected to a LP detector. Usually there is a light and 12 volt switch in the Passenger side outside compartment behind the door in front of the RR tires. The needle valve is a redundant ON/OFF valve. When you turn the outside switch ON and OFF, you should hear a metallic clunk when the solenoid opens and closes. If not, check that solenoid for 12 volt power when the switch is ON. Also, the red indicator light is usually burnt out on older models, so don't rely on the light as an indication of 12 volt power from the switch. You are aware of this switch? Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
Related Content
- Feb 01, 2026Community Alumni
