dspencer's avatar
dspencer
question about my AC cycling on and off
I have a 13,500 BTU Dometic AC on my 26 BH Gray Wolf that I have a question about. First of all it performs great, just got back from 9 days in South Texas and it got a work out for sure.
I happened to notice that on occasion it will shut completely off and will immediately come back on in a lower output if that makes sense. It doesn't appear to have any other problems but I have noticed it coming back on the fan won't be blowing as high. Then other times you will hear the compressor kick off and then it shuts completely off like normal. The shutting off and then kicking back on as a lower fan speed is a new one to me. This is only our second year with this unit and my old one never did that but it was a different type.
Any knowledge on this would be appreciated.
  • you can easly find it online...but here are the cliff notes ;)
    Fan Speed
    Press the On/Off Mode button until the fan green LED is lit. The
    LCD will show “Lo” (Low), “Hi” (High) or “Au” (Auto). Press the “+” or
    “?” button to select the desired fan speed. See “Special Features”
    on page 11 for more information on Auto Fan.
    page 11:
    Special Features
    Auto Fan
    When auto fan is selected the fan speed will vary depending on the
    difference between the temperature set-point and the room temperature.
    In auto fan the compressor and fan cycle On and Off with the
    thermostat.
    When the difference is:
    >5º The fan operates on HIGH
    <4º The fan operates on LOW
    What they don't tell you is... the compressor will still run while the fan changes speed...also you may have it changing back and forth until the temp is reached.
  • I had emailed Dometic about this situation on Friday and they just let me know that it is operating completely normal. Thank You everyone for your answers.
  • Learjet wrote:
    read the "special feature" in the Thermostat manual...
    I have misplaced the manual for the thermostat. Do you mind me asking what it says?
  • dspencer wrote:
    smkettner wrote:
    This Dometic thermostat? The auto-fan selection will change fan speed depending on the set point vs temperature spread. Yes it sounds like it goes off before coming back on at a different speed. All is normal.
    Yes that is the exact thermostat that I have and is exactly what it is doing.
    X2. Mine does the same thing.
  • This Dometic thermostat? The auto-fan selection will change fan speed depending on the set point vs temperature spread. Yes it sounds like it goes off before coming back on at a different speed. All is normal.
  • Sounds like it could be a low voltage issue. Did you check voltage while the AC was cycling? Should never be below 108v and is a common problem in some campgrounds when lots of ACs running.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
