Chum_lee
Oct 27, 2018Explorer
Damdifino wrote:
I've run my Honda 2000 steady for a week at a time when the aux tank and the genny are at the same level. Sweet setup! But I'm wondering if the Honda fuel pump will supply enough lift if it's sitting 4-5' above the fuel tank, which is on the ground. Will it stress the fuel pump?
It's going to take less than 1 psi additional pressure to make the lift. I hardly think it would do damage, but you can see what the pump can handle by setting the genny higher up (maybe on the roof of your truck or your RV) with the aux tank on the ground. See where the pump gives up and the genny stops. Keep the elevation change less than half of the max and you should be OK. (no guarantees) Does the owners manual say anything about using aux tanks? The needle and seat in the float bowl need to be able to counteract the fuel pump pressure. In older carbureted cars it was usually about 4-5 psi.
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
