mippy56's avatar
mippy56
Question on RV toilet replacement
Hoping for a simple yes or no answer but willing to hear you out:
Do you know if a Thetford Aqua Magic IV toilet can be replaced with an Aqua Magic V toilet, with no special requirements?
  • I also want to replace my current Aqua Matic IV toilet for a higher toilet stool.
    What do you feel is a better buy, another Thetford or a Dometic toilet?
  • The only difference is the V is taller than the IV, so if the water connection doesn't have a couple of inches of vertical play, you will need an extension of some sort- a plastic 1/2"x1/2" male nipple plus a short faucet connector with 1/2" swivel on each end will do the trick.
  • Thank you's go out to all 3 Senior Members who responded so quickly. You all concur so I am confident going forward. Love the chart that Bud attached.
  • enblethen wrote:
    I personally would use a better unit with a wider base. I switched to a Bravura.
    X2 on that!!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
