JoeVita's avatar
JoeVita
Question Re: Water Pump Activation
When camping without any hookups, periodically (every 10-15 minutes) the water pump goes on for about a second then stops. Everything is fine when using any of the faucets and they seem tightly closed. Has anyone experienced this? Is it possible there is a small leak that reduces the pressure which would cause the pump to activate? None Are apparent. Could air be getting the the system? What else could cause it and what might be the fix.
Thanks in advance for any input
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
