WesternHorizon
Jan 24, 2019Explorer
Thank you all for the info.
I think you are correct, there is some "wicking" going on. Thanks.
mobeewan wrote:
I'm going to bet that it is the hose and not the fitting. The greasy accumulation on the fitting hex may have migrated upward on to the hex. Transmission fluid is pretty thin and as it leaks it will pick up dirt. The fresh dirt will soak up the fluid and more dirt will accumulate. Add some wind and a little rain and it could very well look like what you have.
