CloudDriver
May 31, 2013Explorer
If your Class C is built on the Ford E450 chassis, the wheel rims are supported and centered by the axle hub, not by the lug bolts or nuts. In the picture below, it can be seen that the rim is a tight fit on the hub and that the lug bolt holes are oversized. Adding a 1/2" spacer between the wheels would move the outer dual beyond the machined area on the hub so that it is no longer properly centered.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
