kilgtfish
Apr 27, 2005Explorer
I forgot to comment on dubman's breaker question..... When you have a 220v circuit, you use both legs of 110v to power a device, and if that device needs 30amps to operate, it has to have 30amp flow trough both legs due to the fact that the legs are operating in a push pull type of interaction. So if a double pole breaker says 30 amp on it that means that 30 amps will flow through each leg. Hope I haven't confused everybody.
Tom
Tom
