azbronco96
Aug 08, 2005Explorer
Actually you can adjust the voltage rather simply. Remove the generator cover then remove the voltage regulator(two bolts)and when you flip it over there is a small potentiometer adjustment screw.Dial it clockwise until the output voltage reads approx 130 volts no load. Then connect the load and adjust engine speed to correct for Hertz. I actually had to slow down the engine as it was about 64 Hz and the microwave didnt like that. 130 no load volts gave me 115 full load volts.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
