Dark_Green_HD_D
Aug 11, 2005Explorer
Hmmm I modded a Champion 3500(as per instructions posted here. Got 119v. at the meter after the mod...BUT in individual test of the windings showed that one was putting out most of the load 86v. to ground the other 33-34v. This unit also has one 20 amp breaker & one 15amp(could these windings be matched to the amp rating for the CBs..one with more cap. than the other?). Plugged it to my 5er & run only the inverter + the 15k AC ...after about 20 minutes the 15amp breaker tripped. I didn't have a amp probe but to me it seems that the 2nd winding may not be pulling it's weight thus overloading the other winding. Now when tested pior to modding, both windings showed 115+v. each. Whats going on here? I'm going to test some more with a amp probe & may even swap CBs & see if the same 15amp breaker trips on the other winding. This is not my gen. The person who owns it had made a adapter for the 220v. plug & tapped only one side for the 110v. draw. I'll check which side it was(15vs. 20amp) I may undo the mod & check it with just the 20amp side & see how this holds up to the camper with the 15k air & inverter on. I'll post my findings.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
