pup
Aug 18, 2005Explorer
Here is what I know for sure. The PowerPro 3500 WILL have to be rewired in order to run everything. I have one, I rewired it and it is now fine. The rewire takes about five minutes if you stop for a break or two. It would not perform to its full power without the rewire.
This unit from Homier Generator
DOES NOT require a rewire. It works fine right out of the box. My parents have this unit and it runs everything in their fifth wheel. You can buy it and have it shipped to you for under $300 and the only difference in it and mine is the paint color and how the panel is wired. Identical engine and exhaust. Just cheaper.
Running both side by side the Homier unit was a little more quiet, no reason that I could tell why but it was quieter non the less....
From what I can gather by reading this thread, the ELM3000 also does not require a rewire. I have no first hand knowledge of this other than what I read here.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
