jmhouse
Aug 24, 2005Explorer
Ok, I received and installed the replacement breaker for my ELM-3000 refurb. Thanks to Emilie at eliminternational! Turns out the breaker along with the voltmeter were literally smashed. Anyway I have two questions regarding the ELM-3000.
1) I seem to getting a considerable amount of smoke from the exhaust. Is this normal?
2) I have an analog voltmeter plugged into an outlet in my TT. When the AC is running the meter needle bounces (pulsates) alot. Mind you that the AC works great while on the genset. The pulsing seems to match the sound from the AC compressor. Also the voltage never drops below the 114v mark while doing this. Is this normal?
Thanks to all on this forum, there is a wealth of information here.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
