mike_65
Sep 29, 2005Explorer
Ok, I have verified the speed governor and/or throttle spring assembly and everything seems to be, as it should. I tested the power output with a Volt Ohm meter and it read 35 volts and fluctuating at normal (suspected) idle...when I manually increase the rpm's (above what I would consider normal for any load) I do see 110 to 135 volts, somewhat stable. When I release the throttle bar, the power drops back to around 35 volts to 0. Of course I am getting the "Nikota is Out-of-Business" reply when calling Pep Boys and no answer to "How do I fix this problem"? I am what some would call a "Jack-of-all-trades - Master-of-none" and know just enough to be dangerous therefore I don't mind bailing off into things as long as I am prepared and have full coverage insurance!! Under some circumstances duct tape and a big hammer have been known to be a man's best friend but for this problem, I would like to actually FIX it. Any help or direction would be greatly appreciated.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
