Caveman3
Oct 19, 2005Explorer
New member here. I joined just because of this valuable thread. I hope you can offer some words of advice.
I have purchased a Powerpro 5500 from Pep Boys. The first one was DOA out of the box. PB exchanged without a problem. It must have been an older model as it had a pair of 23A breakers and a voltmeter on the panel. The exchange has a pair of pushbutton resetable breakers (20A each according to the schematic) and indicator lights instead of a voltmeter.
Fired up the second unit, ran 500W work light, and a small (1 gal) air compressor, no problems. Thinking that if the genset would start and run a 10" miter saw, it would start and run anything in the house. It killed it, no AC, no popped breakers.
Wen sent a new voltage regulator and all seems right. Did not try the miter saw, but was able to run a 1500W heater, the 500W light and start and run the household fridge.
Is it possible that the miter saw was too much of an inductive load? I am concerned because I am hoping to use this to power a gas fired forced air furnace in the house. I think I saw a reference to a "hard start" modification somewhere in this thread, but can't find it now.
Any comments or suggestions would be welcome.
The Caveman
The Caveman
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
