catalina30
Oct 28, 2005Explorer
Bahamaboy wrote:
I have also beenhit hard with Welma and have been running my Elm3000 as i have in the past for my fridge a few lights and TV but just noticed today that the output voltage has droped to almost 100VAC and to my way of thinking i am just ovet 50% load is this common i never noticed the low voltage before?? Is there a way to increase the voltage to about 115VAC??
THanks for any help
Bahamaboy
Yes, there is a screw on top of the engine that has a spring attatched to the throttle, bring the RPM up so as to get your 115v. I would like to remind you before you do this that some have had problems with the capacitor, but as I read it they lost all power when it failed. also you might use the clock trick to make sure the cycle of 60 is still good. My guess is the adjustment locknut is loose and backed off.
Kevin
The Right Lane
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
