dash8wrench
Jun 04, 2006Explorer
In order to most effectively remove the exhaust heat from an enclosure, it would seem to me the most beneficial way is to run the exhaust to an externally mounted muffler. After all, the surface area of the muffler is enormous compared to the surface area of the pipe required to get the exhaust gases outside the box. An additional point is that there are exhaust wraps available from hot rod suppliers that will allow for insulating the exhaust pipe within the box to prevent additional heat "loss" inside the enclosure.
One source of heat wrap
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
