yerlizard
Jun 17, 2007Explorer
Long time lurker around here. I also purchased one of the newer Power Pro 3500 from Pep boys last week. From looking at the wiring diagram, and from plugging things in, it appears to be only 13.5 amps per outlet. I'll scan the diagram later tonite. I would like it to be full power on one outlet!
This has been a fascinating thread to read!
Power Pro 3500 Wiring Diagram, New Model
Overall, I'm very happy with it. I tried to get a Champion thru parts america, but even with the 10% off code, with shipping it was not an option. No one carries it locally. Primarily this is used for back up around the house.
Here it is with a home made wheel kit, from items found in the shed.
Home made wheel kit
I did want to add this. I filled it with oil, filled it with gas, flipped the switch, started on the first pull out of the box. Very light pull to start it. I've run it aobut 10 hours, changed the oil.
Runs great
Home made wheel kit
Runs great
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
