CCTAU
Jun 26, 2007Explorer
jpkiljan wrote:yerlizard wrote:
here is a picture of the wiring on the newer Power Pro 3500
The tab between the outlets is in place and on the red and blue wires going to it. What does this tell you?
does this help any?
Edited to reduce picture width - Mel
It just looks like it is wired they way the wiring diagram says it is supposed to be wired. Well, it is if you assume that you are looking at the rear of the sockets in the wiring diagram. I also assume the little T-shaped slots in the 120V receptacle are on the bottom of the socket when the panel is reassembled--like it is on mine.
--John
OK. New scenario. Say I just wanted to install a 30 amp plug in a box onto the side of my generator. As long as I use big enough wires, can I just use the following diagram and hook up a new outlet? this way the genny stays the same and I get a new outlet. I know that I will need to run the genny in 240 mode, but I'll only be using 120.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
