Wuttevr
Oct 14, 2007Explorer
Old & Slow wrote:
Hopefully you will put the whole system of a Electro-choke and remote start together for us and show the details. My MH genset compartment does have the OEM wiring and start button on a dash panel that might still be usable.
Input from others might also help. Good luck and please stay with this project. I have a Electric Start genny ready to install. (Gas)
Sadly, I am relegated to the cheap seats, as I don't have an electric start model. So I won't be taking this project on. However, I have 100's of alarms, keyless entry systems, and remote start systems under my belt, and would be happy to help in any way I can.
Also keep in mind that this same setup can be used in a 'wired' situation; it doesn't have to be RF remote. With higher amperage relays back at the generator, one could run something as little as CAT5 into the rig to trigger the relays. Might be kind of fun to design and build a generator command center with switches, LED's, and all sorts of other bells and whistle's.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
