skyzoomer
Nov 01, 2007Explorer
Thanks folks for the advice to turn the C46540 off before switching.
Prof95,
Thanks for verifying and yes, I'm going to make a 220 volt extension cord to go from our solar water heater pump to the 220 volt outlet on the C46540. ... In case anyone installs a solar water heater in the future, it would be a good idea to run a 120 volt line to your water heater and install a 120 volt pump for the system. Then the pump could just be plugged into the 120 volt RV output without the hassle of having to switch to 220 volt mode like I'm going to have to do.
Thanks,
Skyzoomer
Prof95,
Thanks,
Skyzoomer
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
