walkers2rad
Sep 03, 2008Explorer
So this is what takes in three phase power from the six black wires on the upper right side, turns it into by my measurements 124.2v @59.85HZ. It meaures the load via those two hand made looking doughnuts you see there (I think) to tell it where to run the throttle and cut off the load if necessary. There are some possibly servicable caps there, some probably for filtering of the a/c noise or smoothing voltages. Beyond that if it stops doing what it does you probably have the rest to part out unless you find another part you are willing to pay for. It does concern me that the inspection tag shows 2kw hopefull that is an indication of what they test it at and not what it is rated for!
It does seem like there are alot of these gens starting to hit the market if the bay is any indication and only difference might be the color of the case.
This is the back of the panel... nothing too exciting here, everything quick connects via keyed and non matching connectors.
Professor... Is there a difference in the claimed digitals and what honda does? Somewhere I read that they were transistor technology and more of a msw output? Just curious cause I dont know.
Tune in later for testing details and a fuel mod for hooking to an external fuel source without messing with the cap.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: Apr 26, 2025
