cdre
Dec 19, 2008Explorer
professor95 wrote:cdre wrote:
Regarding the pickup bed hoists, I bought one at harbor freight and had a subframe welded up to through bolt it to. Subframe was basically two 1/4" plates welded at a 90 degree angle with some long gussets. (snip)
Will it fold down out of the way for use with a fifth wheel hitch?
Can it lift a fifth wheel hitch in and out of the bed of a truck?
Can it lift a 100# generator into the bed of the truck?
Can it be easily removed?
It would rest along the side of the bed rails... I mounted mine on the driver side. I always man-handled my 5th wheel hitch into my truck, but it definitely could have done the job. I just moved it to the side when I towed. It could be removed, but the pivot/anchor post remained bolted to the frame (through the bed). This basically consisted of a section of tube about 4" in diameter and about 12" high. Neatly behind wheel well, so it really didn't get in the way.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
