Emptyspaces
Apr 29, 2009Explorer
Professor,
I've tried about everything I can think of, even completely removing the valve cover vent hose from the air filter housing. It's open and working properly. The governor shaft seemed to have quite a bit of vertical movement compared to my ELM 3000 so I added a thin washer under the clip to raise the shaft slightly and reduce the slack. This had no effect of the leak.
As this is a new engine excessive wear isn't the problem.
Out of curiosity, on your engine, does the washer fit snug against the case or does it have notable clearance?
I would appreciate any insight Paul might have on the problem.
Thanks!
Thanks!
