tubular031
Jul 16, 2009Explorer
Both springs are there and hooked up as they should be.
I am thinking its something to do with the part that controls the motor speed. I assume there is something in there that watches the RPMs and tells it to speed up or slow down to keep the right speed. It seems like it thinks its going too fast so it tells the motor to slow down. then it thinks its too slow so it speeds up aka pulse. On our motor controls there is a POT for adjusting how fast to adjust, if you turn it too high, the motor does the exact same thing as my champ is doing. Same thing when you tune a servo system.
If I pull the arm off the carb and work the throttle my self the engine runs fine.It idles fine and accelerates smoothly. and it also over revs too...oops!
I am going to call champ again and get a warranty claim going. unless you guys can think of something else to try.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
