cnsayre
Oct 09, 2009Explorer
professor95 wrote:cnsayre wrote:
Dang it. My C46517 has a fuel leak. It's either in the fuel line or the shut-off valve. The fuel line is easy enough to change. Anyone out there replace the shut off valve? I'm hoping there isn't something INSIDE the gas tank, such as a nut, that needs to be held when removing/reinstalling the valve. If there is, that's going to be painful...
No nut inside. The petcock just screws out after loosening the jamb nut on the bottom of the tank.
Check the jamb nut to be sure it is tight. Also the gasket under the nut. Be sure the tank does not have a crack - they can develop at the petcock attachment.
Some petcocks can be disassembled. If yours is one be sure the two tiny Phillips screws are tight on the plate behind the lever.
The cost of the new fuel valve from Champion was something like $5. For $5, it's not worth trying to rebuild the valve.
And thanks. This is this weekend's project, if I manage to find time between a houseguest and two weddings to go to...
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
