VDOCAD
Apr 18, 2010Explorer
Jer&Ger wrote:
ADOCAD,
The right end hooks where the rod is connected, the left end connects in a tiny hole in the plastic just below where that end of the rod connects. However, looking at your pic, it looks like the spring broke off about an inch or so of the end which had been straighten with a hook on the end. Hope this helps some how. I took a pic for you, I'll try to get it downloaded.Here is the link to them.
Thanks a lot for the quick response. It looks like mine broke right at the hook where it starts to bend... I measured the straight part of the spring and it seems to be about 2.5 inches.
Does anyone know if this is a Champion only part or pretty generic on generators since these Honda-like engines are standard on a lot of genys? I have been looking for a generator parts retailer in the Richmond, VA area with no luck so far.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 21, 2025
