Cox89XJ
Nov 15, 2011Explorer
tvsteve wrote:MrWizard wrote:
sounds like the engine speed governor is sticky
try unbolting the gas tank, remove it, and do a thorough lube and clean of the governor lever at the top of the engine
also there is a very fine lite weight long spring connected parallel to the governor linkage to the carb throttle, that will cause "hunting" (speed variation) if the springs breaks
Inspected and lubed the linkage. It's free and not binding. Still, the problem persists. It's more of a slight misfire than a surging.
Steve
You might try disconnecting the low oil shutdown circuit. Mine failed.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
