I keep watching for an answer so that I might understand your question. (It's me... not your question)
Are you saying that you had a LED light that was switched:
1) off
2) on low
3) on medium
4) on high
I have changed out all of my screw based incadesent and CFB bulbs that are in use more than a couple of hours per day at home for:
Cree LED bulbs (their color accuracy is 93 where most other LEDs in the same cataagory are on 80 color correct.) I have them in 40 W, 60 W, and 100 W equivalant.
They are all dimmable.
Questions:
Are all LED lights dimmable?
If so, could you possible just replace your switch to a conventional three way switch?
I don't think so... at home our three way lamps with the dimmable Cree LED bulb replacements only work in one position... full on
Have you considered installing a dimmer switch in place of your on/off switch in your new camper's light fixture
There will be some one on here that will know (and some few that will make good or wild guess's...)
Let's hope we get good answers
It occurs to me to add an inline dimmer... since I like about the same amout of light most of the time... and use the lamps on/off swich to activate or shut down the light at the dimmed setting.
You have asked a good question as we progress up the technology road.
Sleepy
