rvshrinker's avatar
rvshrinker
Explorer III
Sep 05, 2020
RV dinette light wiring questions
Finally getting around to trying to replace this. OK, I procrastinated, used duct tape, and then it all fell apart (down) on yesterday's drive. When it fell a lot of the wiring came apart.
There are two lights. The two lights are connected by two white wires which are joined by a clamp connector. The lights are also connected by two black wires joined together in a twist, which I think came out of the clamp connector which is still attached to the ceiling. There is a third black wire running from the switch to the twisted black wires.
Coming out of the ceiling is a green wire, attached via a clamp connector to a black wire that clearly goes into the switch, and a white wire which I think goes to the white clamp connector.
Does this all sound correct? I'm not sure why there are two black wires coming out of the switch and why they both connect to black, and not white.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
