Old-Biscuit wrote:
HERE is a service manual that covers your model (2652). pg. 22 has all the proper dimensions for installation.
Fan should be center line of fridge and 38 1/2" above floor of fridge.
Thermodisc should be on on far right of condenser coil.
Thank you, I found and downloaded all of the manuals except this one, I never saw this one - must have missed it. The fridge is mounted exactly as it is supposed to be, fan in the right place as is the thermal switch. After reading everything I could, and looking at the installation it could very well be that the fridge is just not getting enough air flow without the fan running, so there is a couple of things I can change to increase airflow through the "chimney" so to speak. I will repost the results after I get a chance to make the recommended fixes. Thank yo all for posting, I appreciate the help!
