Re: How do I level a dual axle trailer???
I will block 1 or both axles on the side depending on how much lift I need. 1 axle gives you half the lift of the block height; so 1 2X10 = 1.5" thick will give you 1.5" lift when placed under both axles, but will give you only 3/4" lift when placed under one axle.
I'm cheap, and carry scrap lumber for leveling. But for you, go get some more blocks so that you can build enough of a ramp and have enough lift as required.
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
