theoldwizard1
Nov 17, 2020Explorer II
Re: What roof paint / sealer do I need? Jayco Eagle 2007
campingwiththoreau wrote:
PS- The PO painted the roof once a year. I’ve owned it for 5 years and have only cleaned the roof and used a roll-on clear sealer. I have 2 areas in the bedroom where water / moister intrusion is evident. I do not see any damage or holes on the roof in the vicinity of the apparent intrusion.
Most RV used a type of rubber roofing called EPDM. Based on your RVs age (over 10 years old) and because you have evidence of leaks, it is time for a complete tear off, inspect, replacement of any rot, new decking and roof.
Re-coating annually is not necessary, even in places with a lot of UV. What should be done is wash the roof and apply a good UV protectant, like 303 Protectant, twice a year.
