- otrfunExplorer II
Teleman wrote:
I prefer using a battery isolator because it requires >13.3v to activate the dc to dc charger. Zero chance of inadvertently discharging the starter/TV battery—ignition on or off.
I only turned the ignition on to measure the current briefly out of curiosity before I started the motor. The charger activates with a signal from the ignition. The output current is about 43A at higher rpms and 48 at idle like I said.
I was hoping it was your input current fluctuating. Very unusual for charge current to fluctuate like that based on alternator rpm/output. The whole purpose of a dc to dc charger is to stabilize the charge process. - TelemanExplorer
otrfun wrote:
Teleman wrote:
Any particular reason you would allow your dc to dc charger to be on-line when the alternator is off-line? Most use a battery isolator or trigger wire (found on most dc to dc chargers) to prevent the dc to dc charger from inadvertently discharging the starter/TV battery when the alternator is off-line for any reason.
. . . Input current to the Redarc gets as high as 54 amps with the ignition on without starting the motor . . .Teleman wrote:
Are you saying the output or input current climbs to 48-49a at idle?
Output current stays about 43 amps when driving and climbs to about 48-49 at idle.
If the output/charge current climbs to 48-49a at idle, I'd have to agree, it's definitely out-of-spec. How high did the input current go?
If you're referencing input current to the dc to dc charger, then 48-49a would seem perfectly normal with the alternator operating less efficiently at idle (higher voltage drop forces higher current).
I only turned the ignition on to measure the current briefly out of curiosity before I started the motor. The charger activates with a signal from the ignition. The output current is about 43A at higher rpms and 48 at idle like I said. - otrfunExplorer II
If you're referencing input current to the dc to dc charger, then 48-49a would seem perfectly normal with the alternator operating less efficiently at idle (higher voltage drop forces higher current). - TelemanExplorer
wa8yxm wrote:
Ok DC/DC chargers are voltage converters. they work one of two ways (Buck only or Buck/Boost) if boosting the amps in go up as the volts out go up.
And they also draw "overhead" power.
How to limit the current so the breaker does not pop I do not know other than a longer wire.. I'd not recommend a smaller wire, between the unit and the battery Make sure the wire can haul the full 40 (in fact 50 to be safe) amps but lengthen it so the resistance limits the current DO NOT COIL IT
Replacing the cheap breaker with a quality Blue Sea unit did the trick. - wa8yxmExplorer IIIOk DC/DC chargers are voltage converters. they work one of two ways (Buck only or Buck/Boost) if boosting the amps in go up as the volts out go up.
How to limit the current so the breaker does not pop I do not know other than a longer wire.. I'd not recommend a smaller wire, between the unit and the battery Make sure the wire can haul the full 40 (in fact 50 to be safe) amps but lengthen it so the resistance limits the current DO NOT COIL IT - TelemanExplorer
S Davis wrote:
Oh ok mine is not triggered by the ignition, it is sensing voltage to trigger it on and then after about 30 seconds slowly ramps up the amps. I wonder if you got a mislabeled 50 amp unit?
Maybe? That works for me. - S_DavisExplorerOh ok mine is not triggered by the ignition, it is sensing voltage to trigger it on and then after about 30 seconds slowly ramps up the amps. I wonder if you got a mislabeled 50 amp unit?
- TelemanExplorerAll cabling is well within spec. The starting and house batteries are within two feet of each other and the charger is next to the house battery. Replacing the tripping breaker with a Blue Sea unit solved the problem. Input current to the Redarc gets as high as 54 amps with the ignition on without starting the motor. Settles to around 45 with the motor running. Output current stays about 43 amps when driving and climbs to about 48-49 at idle. This seems somewhat out of spec but it's certainly acceptable to me in terms of performance.
- S_DavisExplorerMaybe it is wire size, I use 1/0 DLO cable rated at 270amps so I don’t have much voltage drop.
- otrfunExplorer IINot sure if all Redarc dc to dc chargers operate the same. It appears some Redarcs may set an output/charge current ceiling (and vary input current), whereas other models may set an input current ceiling (and vary output/charge current).
Our 40a Renogy dc to dc charger can vary the output/charge current from 0 to 40a. After 9 months of heavy use, under all conditions, I've never seen the output/charge current increase beyond 40a---it's a hard ceiling. Although the *input* current on our Renogy always stays below 45a, some installations (with longer cable runs & smaller gauge cables) can force the input current to rise as high as 60a to compensate for various voltage drops between the alternator and Renogy input.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
