Loganhorse's avatar
Loganhorse
Reese WDH
Found this older bar. What is it rated for on tongue weight?
1" square spring bar
Strait-line 550#
Frame 450#
Axle 600#
Confused on what these mean?
  • JBarca wrote:
    By chance can you post a picture of the WD bar, the label if it still has one, and the hitch head if it is from the same vintage?
    From what you listed, it is not the normal post year 2000 ratings of the actual WD bar.
    By seeing the parts, may be able to back into what basic age range and that may help lead to the rating.
    I believe the "round bar" versions replaced the older "square bar" versions.
    The 550 lbs rating is the Tongue weight and it is for trailers a 5,500 lbs or lighter..
    In other words a small, short lightweight trailer.
    See info on the round bar version HERE
    Unless OP has ALL the parts including the hitch head it is only worth scrap metal prices..
    I have inherited a couple of WD units like that without the hitch heads, the replacement hitch heads cost more than the bars..
    Yes. Give me 15 minutes or so
  • By chance can you post a picture of the WD bar, the label if it still has one, and the hitch head if it is from the same vintage?
Having RV issues? Connect with others who have been in your shoes.24,312 PostsLatest Activity: Sep 06, 2025
