Chinolbz
Jun 28, 2015Explorer
Refer not cooling on AC
Hi Guys! On the road with a Dometic 8ct. refer problem. Cooled down fine on AC in Havasu at 116 but here in Moab at 102 was not cooling down. Freezer @ 12, refer @ 45. Switched to propane and all appears OK. I would like to troubleshoot the AC side of things. I have read here that the first step is to wire the AC directly to the refer so that it eliminates the circuit board out of the system. So can someone explain to all of us how to do this? I guess I have to make a AC pigtail and connect it directly to the circuit board of the refer? Is this behind the black cover on the back side of the refer or? If it cools down does that mean the circuit board is bad? What else if anything can I do in a RV park? Thanks Chino
