jillhop's avatar
jillhop
Refrigerator thinks it's a freezer ...
My trusty RV tech went off to Florida for the winter, so I had to try out a new guy to deal with an issue that I was having with my refrigerator intermittently not lighting on gas. In the course of working on that issue (which I actually think is a corroded wire between the main board and the ignitor), he removed my main board and replaced it with what I think was another random used board. Since then, the refrigerator will only run if it is over 40 degrees outside (despite running a space heater in the coach with the refrigerator door open leading to 60 degrees in the refrigerator...) and when it does run, within 6 hours the temperature in the refrigerator is down to 10 degrees. Thankfully, my regular RV tech is back from FL and is going to put a new control board in tomorrow, but I have some questions in advance.
Thinking about it, the refrigerator is acting like the temperature sensor is sensing the OUTDOOR temperature, not the temperature in the refrigerator. Is this possible??? The normal temperature sensor looks like it is in place inside the refrigerator, attached to the plastic bracket on the fins at the back of the refrigerator.
Or, could it just be a bad controller board?
I have used this refrigerator many times in the past in cold weather below 32 degrees. Once we get this sorted out, we will get to the original issue of not lighting intermittently on gas ...
Any ideas/comments on this would be appreciated. The refrigerator is (I believe) the original refrigerator in my 1998 Coachmen Class C, Dometic Model RM 2652.
