buylow12
Oct 23, 2018Explorer
I tried unplugging the thermistor early this morning but only for about maybe two hours and didn't notice any difference so I plugged it back in but I've done that again and will let it go for longer this time.
Unplugging the heater element leads sounds like something I would like to try from your description. It sounds like it could eliminate the board being bad. Unfortunately I don't quite understand what you mean. How would I go about plugging them into a 120 volt outlet directly? Could you give me some more detail as that seems like it would be a definitive test if the cooling unit is shot or not.
I really don't want to replace the entire cooling unit if I don't have to, the last time I had trouble with the fridge I was told by multiple people that it was the cooling unit and it just ended up being the thermistor. The only thing I can think of is perhaps the board but the test you mentioned would allow me to rule that out. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
