joebedford's avatar
joebedford
Nomad II
Jan 10, 2016
Replace Schwintek slide roller?
Does anybody know if it's possible to get the shaft out then slide in a replacement roller?
  • Do you have a Forest River RV? There have been some issues with the main slides tearing the Darco wrap although your picture shows something other than the Darco.
    Depending on where the slide is at any given time on opening or closing one or both of my rollers will skip and then begin to turn again. I suspect that that is caused by the bottom not being perfectly flat.
  • You can cut the rubber wipe seal by the roller and then use LONG needle nose pliers to pull the wrapped rubber out from the roller. I HAVE done this before also. I doubt your roller is bad, it just has that rubber torn and caught and needs removed. You will have the slightly raise the room to relieve the tension on the roller to get the rubber removed. Raising the room that 1/4 inch will not harm the Slide side mechanism's. Doug
  • Yep - weatherstrip.
    I went out with a flashlight and glasses and DW moved the slide a couple of inches. The other three rollers rolled and this one didn't - the slide slid.
    I was able to remove the weatherstrip (what to replace it with?) and the roller rolled fine.
    Now I have to repair the damage it did to the 'wood' base of the slide.
