kahoona
Jun 02, 2015Explorer II
Hi
Thanks for your direction so far. I have checked all of the relays on the Power Distribution and the relay panel above the radiator and they are good. The scary thing is that they don't seen to control what the manual says they do! As you suggested I will locate the backup light wire and add a relay. I would prefer not to have to connect at the rear lamps and string the wire along the frame to the front if I can help it. Do you know if I the backup light feed originates in the steering/shift column? There is a fuse but it is ahead of the switch (always on) of it it goes through a relay under the dash? I cannot find any info on the coach wiring.
Thanks
Thanks
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
