kahoona
Jun 02, 2015Explorer II
MrWizard wrote:
I think you will find the reverse switch
attached to the shift linkage, but Not inside the steering column
it used to be common for it to be attached to the shift linkage under hood along side the steering column
Now that you mention it I haven't actually seen the shift linkage. I'll look for it and check for that.
Here are the wires coming off of the shift lever bottom area and I wonder if one of these is what I need to use.
Here is an overall view. A lower cover hides some of the rats nest of wires.
Hope these come out. Hope they help.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
