Gdetrailer
Feb 22, 2022Explorer III
BurbMan wrote:
I had the same furnace, and there's no pilot. According to the parts diagram it's electronic ignition. Are you looking for the igniter?
The one you had, may not be the same as the OPs.
Hydroflame 8012 "P" is not the same as Hydroflame II..
"P" is for Pilot..
The II is DSI..
I had a 1980s TT which had a 12K BTU Hydroflame, don't remember the exact model, but it indeed had a pilot light that had to be manually lit.
I suspect as long as the pilot tube is correct dimension and has the correct fittings it should work. Just need a means of transporting the pilot light gas to the pilot lite at the burner..
A universal Thermocouple as long as you have one with the correct electrical end fitting probably would work and if you can find one that isn't too short or too long of wire.
I would be much more concerned about the condition of the heat exchanger as you are dealing with a 40+ yr old furnace..
