Kevinski
Mar 01, 2022Explorer
ernie1 wrote:
That yellow goop you see on the gas line is a gas line thread sealant like a product called Rector seal. Becomes flexible when warmed up. I would try a six point flare nut wrench and a hammer to strike the end of the wrench on both nuts that you are trying to loosen. A little bit of heat would probably help loosen the larger gas line nut but I wouldn't overdo it.
Thanks Ernie, I'll try that if I end up needing to remove that fitting.
