- Charlie_D_ExplorerCheck Amazon. You can get LED bar lights for less money that the ones on the link. They have some with a lifetime warranty and made in the U.S.A..
- beemerphile1Explorer
2CAJUNS wrote:
Though about changing fixture but can't find one that matches size of what is on there now. 2015 Montana High Country. Thanks.
How about keep the originals and install additional LED trailer fixtures?
Command Electronics is a brand that a lot of OEM use;
http://www.commandelectronics.com/shop/ - 2CAJUNSExplorerThough about changing fixture but can't find one that matches size of what is on there now. 2015 Montana High Country. Thanks.
- beemerphile1ExplorerChange the fixture, not the lamps. Most LED lamp replacements do not provide very good illumination in this use. The original tail light fixture is designed to work with an incandescent and the way it gives off light. An LED is more directional.
- 2CAJUNSExplorerOk, thanks. would it be best to change out all 4 bulbs or just the 1156
- corvettekentExplorer
2CAJUNS wrote:
I want more visibility when stopping or signaling of my 5th wheeler. What is best option-changing out the standard 1156 and 2057 bulbs with led bulbs or purchase new led tail light kit. Auto Zone says I will also need a resistor strip because the flashing signal will become too fast. Any recommendations?
You will not need a resistor strip because this is a trailer. You would if you replaced your truck tail lights. - AnonymousI went with replacement assemblies and they made a big difference. And I did not change the flasher but it is a heavy duty electronic style many trucks have.
- 1492ModeratorMoved from Forum Technical Support
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
